hdlc
So when you "Manipulated" your DLL was the original script in C++? or did you "manipulate" it by using labview itself?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 11 of 16
(1,579 Views)
CommTech provided an example in C++. We got it working with CVI. Then created a dll which was used in the application.
There is another way if you want to avoid the dll. The VISA DDK provides the ability to design an interupt driver that punches the registers required etc. To use that tool you need to be familiar with the workings of the hardware, the registers and their signifigence.
Ben
Message 12 of 16
(1,570 Views)
what is CVI?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 13 of 16
(1,559 Views)
I beleive Ben meant NI's LabWindows/CVI. A C compiler made by NI. But I could be mistaken.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 14 of 16
(1,549 Views)
no you are currect
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 15 of 16
(1,542 Views)
I am going to probably use the FastComm chip you said they have example software for the dll is the dll the application itself or is it just a driver for the chip? and if it is just the driver for the chip can i impliment my own labview application for transmitting and recieving HDLC?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 16 of 16
(1,514 Views)
