handling refresh of variables within an event structure?
Dear all,
here I have my problem: I implemented in a data visualisation tool a button for getting the most updated file.
But as the mail application shall deliver new files every 2-5 seconds, I wanted to implement also an automatic refresh function, so that the updated file is picked every XX seconds.
I tried several, maybe naif workaround, but the problem is that when I start the "Automatic refresh", I can not handle anything else in the Control panel, and I can not change the value of the "automatic refresh control" because probably ... it is waiting. Please find attached the picture.
What am I missing?
thanks in advance,
Edo
(2,929 Views)
Accepted by topic author Edo777
Hi Edo,
you can use the Timeout Event for it. Don't use a wait function inside of an event structure.
Mike
(2,923 Views)
HI
Just edit the event case and remove checkmark Lock front panel until event complete (At the bottom of event case when you edit the event case)
 I hope this helps
Regards
Santosh
(2,922 Views)
thanks a lot for both of your hints!
finally I adopted the timeout solution, thank!
(2,893 Views)
