h5labview - column names
Hi
I am using the h5labview library (h5LabView). I like to write an array of dbl to the data file.
Is there a possibility to set the dataset column names Please find attached a picture ilustrating what I like to do.
The pictures shows only the HDF5 write data part of the program. The array size as well as column names are retriven from a config file at start of the SW.
Best regards
Reto Tröndle
(2,890 Views)
I've never used h5 but I see there there are a couple toolkits for LabVIEW.  I wonder if they all have this issue.
http://www.upvi.net/main/index.php/products/lvhdf5
http://h5labview.sourceforge.net/?home
Also I'd suggest contacting the developers, or finding some way to ask them about this issue.  You may find people here that have used this toolkit, but the developers should know right away if something like that is possible.
(2,862 Views)
