group stacked bar graph with respect to the date period
Dear all,
I have a problem about the stacked bar graph and don't know if it is possible to do that...
I would like to plot all the stacked bar graph together with repect to the date period as shown in the attachment...
actually is it possible to do that ?Smiley Sad
Thanks in advance,
Io
(3,962 Views)
Hi lo,
I think all you need to do is implement the code found below. What you need is instead of using the random numbers (like in my example), you would just give it the values for you bar graphs. You can then build an array where you append the values for the second color above the first color by using the add function. If you then go into the plot legend (left click and go into bar plots), you can change the presentation of the data on the graph. You will also have to change the common plots display in the legend as well (left-click and go into common plots). I hope this helps!
Message Edited by CarlaU on 04-10-2008 09:13 AM
(3,933 Views)
Thanks for your reply.
I get the idea.Thanks.Smiley Happy
Io
(3,921 Views)
How can you include the date period in the stacked bar
(2,543 Views)
Hi Sahaana,
This is a very old forum post. Per the community rules, you should make a new post so you can hopefully get more traffic since more forum users will have a chance to see your questions.
(2,516 Views)
