gregorian calendar to solar calendar converter
hi I want to use my PC date and time in my vi but it is in Gregorian system and i have to convert it to solar system but i found this conversion has some especial leap days, beside each 4 years leap year we have another leap years for that float number for example each n year leap years change to 5 years instead of 4 years! have any of you a reliable vi for this conversion? regards
(3,717 Views)
Why does this sound like a homework problem?
I'm also not aware of a "solar system" calendar. How does it work on Jupiter?
(3,712 Views)
I've never heard of that one before.  Can you provide a reference talking about a 5 year interval?  Are you talking about that century years are not leap years unless they are divisible by 400?  (e.g. 2000 = leap year, 1900 <> leap year)
(3,703 Views)
hi solar years are like Gregorian years on Jupiter but the start and it's corrections are different for example in Gregorian years 2012 is a leap year i mean the 4th year of each 4 year is leap year but in hijri shamsi (Persian calendar) 3rd year is leap year Dear Ravens Fan that's true (e.g. 2000 = leap year, 1900 <> leap year) is Gregorian correction but in solar correction there is another method all in all in need a Persian calender converter
(3,684 Views)
i found persian calendar correction graph
every 33 years it correct itself Gregorian calendar is different
(3,678 Views)
You are probably going to have to research the the algorithm and program it yourself.  The rest of the world uses a normal calendar so all time and date conversions are based on that.
(3,661 Views)
Your images seem to come from this wikipedia entry: http://en.wikipedia.org/wiki/Iranian_calendars
At the bottom of this entry is an external programming link to the Microsoft MSDN library. There is a .NET function that you might be able to use instead of coding the solution yourself.
http://msdn.microsoft.com/en-us/library/system.globalization.persiancalendar.aspx
There is also a link to a JavaScript example
http://farhadi.ir/projects/jalalijscalendar/
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
(3,653 Views)
