greater than function not sourcing bool?
Highlighted
HI, I have the following.
Whenever I try to connect the 'Greater than' output to the AND function I keep getting a connection error "Dynamic type not Bool" well something like that. If this is the case how come I was allowed to connect the 'Less than' function to the AND?
Message 1 of 19
(1,134 Views)
Highlighted
Wow this is some new thing, I am also seeing the same in 8.6 version, Lesser than VI outputs dynamic data but not greater than VI. Nice question.
Message 2 of 19
(1,122 Views)
Highlighted
Interesting.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 3 of 19
(1,112 Views)
Highlighted
Both output dynamic data but only one input of the AND can be dynamic. More evidence to avoid the (evil) dynamic data type. The input to the greater than/less than functions should be converted to a scalar or 1D data - whatever it actually is.
Message 4 of 19
(1,110 Views)
Highlighted
I don't use dynamic data either, but in your case you could use the limit testing express VI.
Message 5 of 19
(1,102 Views)
Highlighted
Hi, I have looked in the help file to convert from dynamic and it tells me to look in the 'Express palette' but the vi isnt anywhere to be found?
Message 6 of 19
(1,093 Views)
Highlighted
It is under "express.signal manipulation". Look for "from DDT".
Message 7 of 19
(1,089 Views)
Highlighted
Thanks but I'm more confused now.Smiley Sad
I would like the output of the conditional block to give a Bool. So if the input signal is between two levels then I just get a 1??? (like every other computer programming langauge)
Message 8 of 19
(1,084 Views)
Highlighted
if (x>a) AND (x<b) then TRUE
Message 9 of 19
(1,082 Views)
Highlighted
  • You can first convert the original data to an array and then do the comparison (e.g. using in "range and coerce")
  • or you can say that you want a boolean output in the "From DDT" dialog.
Message 10 of 19
(1,079 Views)
