greater than function not sourcing bool?
HI,
This is what I have should I be converting the output of the logic gates? The error says that I need that the sink is a Bool but the source is a 1D array of Bools?
Message 11 of 19
(848 Views)
Right-click the comparison and change the comparison mode. If you want a single boolean, select "compare aggregates".
(You are comparing the arrays element by element at the moment.)
Message 12 of 19
(844 Views)
If I do that this happens,
Message 13 of 19
(842 Views)
Don't do it on the first ones.
Message 14 of 19
(838 Views)
Sorry I dont follow you.
Message 15 of 19
(834 Views)
For the four leftmost comparisons (the ones comparing with scalar diagram constants), leave the setting at "compare elements" instead of "compare aggregates.
Please look into in range and coerce for simpler logic.
Message 16 of 19
(831 Views)
I'm lost. The only blocks that have the comparison option are the four blocks on the left of the logic gates. The gates dont have that option.
Message 17 of 19
(829 Views)
OK have sorted it,
Seriously though, it no wonder embedded system guys stay well away from LabVIEW when something this simple is so complicated.
Thanks for your help.
Nic
Message 18 of 19
(827 Views)
Ah, sorry. Just pipe it through a AND array elements or OR array elements, depending on what you want. 🙂
(Do you want it to be true if all elements are true or if at least one element is true?)
Message 19 of 19
(822 Views)
