graph proprieties size disabled (grayed) (can't resize graph with front panel)
I have 2 graph in a tab control (Main Vi).
When I resize the front panel while ''scale all objects on front panel as the window resizes'' is enable.
Only one of theses two graph resize.
I noticed that the graph that won't resize has its size option disabled and grayed, when I look in th graph proprieties (As seen on this picture)
Is there a way to enable the size or resize the graph with the sames proportions as the other one. (I already tried to group then togther, lock them..)
Message 1 of 8
(3,637 Views)
I tried the same here with the VI i created and it works fine.
So, i must be missing something that you have mentioned below. I am not able to replicate your problem.
Will you be share me that VI so that i can replicate and see what i can do?
Muthuraman. S
Muthuraman
Message 2 of 8
(3,608 Views)
Here are the Vi. if you scale down the window, the graph on the right (BAD) will not resize correctly. according to the graph on the right.
Message 3 of 8
(3,590 Views)
If I delete the graph and put a new one, it allow me to resize the graph while resizing the front panel, but it's not what I m looking for.
Message 4 of 8
(3,570 Views)
What are you looking for then?
It seems there is some corruption with the bad graph, so just replacing it with a new one seems reasonable to me.
Message 5 of 8
(3,562 Views)
It's reasonable, but I have 10 graphs and I Use Property Nodes, so if Star to change them it's gonne ben a mess. at least if you know a way to keep all the property nodes.
Thanks.
Message 6 of 8
(3,554 Views)
  1. Create the new graphs first
  2. Right-click the property nodes and link them to the new graph
  3. Delete the old graph
Message 7 of 8
(3,550 Views)
I don't know why this worked, but I had a similiar problem. So, I right-clicked on the indictor, then went to advanced, and selected customized(ie turned it into a control). Once the control poped up it allowed me to make changes to the size. So, I copied and pasted the indicator into my main and I was able to adjust the indicator like normal.
Message 8 of 8
(3,361 Views)
