This KB says to "Right-click on the axis that you want to have multiple scales and select Duplicate Scale". Once you do that, you'll have two scales and then you can just access the Properties » Display Plots and set one scale for absolute and relative time.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
