06-29-2010 08:53 AM
Hello!
I am trying to read input from a voltage meter. I would like the analog input to be shown in real time on a graph on the front panel. I'm think this is an easy application of labview (reading analog input and graphing voltage vs time) but I am having trouble finding an example compatible with usb 6212.
I was hoping someone could point me in the right direction of an example to follow from the example finder?
Thanks so much!
06-29-2010 09:37 AM
Virtually of the examples with 'Acq&Graph' or 'Cont Acq&G' in the name can be used. Don't know why you can't find them. Start with the basic 'Cont Acq&Graph Voltage-Int Clk'.
p.s. Reading from a voltage meter does not make sense when you say you are using the USb 6212.
06-29-2010 11:29 AM
Thanks! I'll take a look there...I was looking and didn't have much luck...
I have a voltage meter pluged in the usb 6212, will that not work?
06-29-2010 11:36 AM
You have it plugged in to do what? How do you have it plugged in? A meter does not output anything so what would be the purpose? Your pc and DAQ card could be considered a multiple channel volt meter.
