08-27-2014 11:49 PM
hello all.. this is rohan here..i am new to labview, i am doing a very simple VI on getting analog pulses from DAQ USB 6008 by measuring harmonic currents and comparing it with a triangle wave. i am geting the pulse. but how do i extract it out from labview? i should give those pulses to a single phase inverter i.e., IGBTs.
the problem here is..while i am connecting the output DAQ its showing an error. i am attaching the jpeg of the VI and the error..hoping a reply soon..correct me if im wrong as i am still a novice in labview.
08-28-2014 12:04 AM
As per Error Message, you’re reading 2-Channel data but writing One-channel data to DAQ.
08-28-2014 12:11 AM
yeah..but how do i solve this? its clear that the samples for the input daq ought to be N-SAMPLES or CONTINUOUS. but for the output daq im unable to take continuos samples..its showing an error for evry other sample except for 1 sample on demand. so they dont match and hence dat error..!!
08-28-2014 12:16 AM
08-28-2014 12:34 AM
so..whats the solution for this? if i cant get the pulse out.my project wont move an inch.. and if i keep the input daq in one sample on demand..it isnt showing any waveforms and the axis are moving at a rapid pace without showing the wave..
yes ive read the discussions on analog output..bt neither they are mentioned about the input samples..but for me the eror lies with the samples only 😞
08-28-2014 12:45 AM
08-28-2014 01:10 AM
Wire that to a for loop with a DAQmx Write inside set for 1ch 1samp.. can u please elaborate a bit?
08-28-2014 01:20 AM
