08-06-2018 05:27 AM
hello,
i am having problem in programming of extracting one value(particular element) from an array with a given condition which is dependent on the another array.
for example, lets say i have a set of data from -1v to 1v with their corresponding current . all these data voltage and current are in a two different array .
now if i want to get an element in current corresponding to which the element value in voltage array is zero.how do we find that?
i tried to put in a way as we do in c with two nested loop but here i am not able to do it here.please anyone help me out of it.atleast give a initial 2-3 steps what to do.
Solved! Go to Solution.
08-06-2018 05:34 AM
Search the voltage array to return the index of the match then use the index to select the item from the second array. Simple! or am I misunderstanding your problem
Ken
08-06-2018 05:37 AM - edited 08-06-2018 05:39 AM
08-06-2018 05:42 AM
but what if i am not getting the exact value of it say i want current when voltage is 2 V BUT IN DATA its slightly greater than or less than it,then how to solve this
08-06-2018 06:05 AM
Hi iyot,
Use the suggestion from my previous post!
It will interpolate (using the Interpolate1DArray function) between the points defined in those voltage/current arrays. Any outliers are limited to min/max of your point array(s).
08-06-2018 06:17 AM
thanks a lot 🙂
08-06-2018 11:20 AM
well,its not giving the value as required.in short the way you suggested is not working
08-06-2018 12:23 PM
What Gerd told will work if written correctly.
If your code is not working then there is trouble with your code. Unfortunatly my eye are getting old and I can not quite make out what you have coded from where I am sitting.
Show us the code.
Ben
