get references to all controls on front panel
Hi everyone
I thought this should be quite easy, but it is proving more trouble than I originally thought.
My goal is to, only once, set all the controls on the front panel to have their "skip when tabbing" property set to false.
Now the front panel has all kinds of nested tab structures etc. Is there a quick n easy way to get the references of *all* the front panel controls, regardless of whether they live inside a tab control or not.
As I said, I only want to do this once, so I suppose I could go around manually changing the property on each control Smiley Sad
The openg toolkit does not seem to have any tricks up its sleeve for this, or maybe I am missing something.
nrp
Message 1 of 10
(14,065 Views)
You're not missing anything. You have to do this recursively because of the class hierarchy.
Message 2 of 10
(14,059 Views)
The only way I have found is to do an iterative process. Get the array of references to the controls. Loop through the array and find the compound controls (tabs, clusters, radio buttons, ...). Then get references to the controls inside the compound controls and repeat until all controls are the elementary ones.
Lynn
Message 3 of 10
(14,058 Views)
In the "Application Control" pallete get the "this vi ref" wired into a property node->Front Panel. Wire that reference into another proprety node and select Controls[]. That gives you an array of references for all of the controls, put that into a FOR loop with a property node inside with skip when tabbing selected and a flase wired into it.
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
Message 4 of 10
(14,053 Views)
That will not return references to controls embedded inside of the those controls, which is what nrp is looking for. Smiley Wink
Message 5 of 10
(14,051 Views)
For tabs get a reference to the tab. Property node Pages[] indexed to FOR loop. Poperty node for Controls on Page into FOR Loop, property node for desired control change....
Message 6 of 10
(14,039 Views)
thanks for the answers, although I was hoping for something slightly less troublesome than iterating through all the compound structures!
At least, for my app, I only need to go down two levels (a tab control within a tab control).
Maybe I will do it manually, maybe not, we will see how I feel in two hours or so after gymn, that normally motivates me to try new things in labview  Smiley Tongue
Message 7 of 10
(14,033 Views)
Hi there,
hope helps the next, with the same problem...
http://digital.ni.com/public.nsf/allkb/D7A289CB44CD1EAB86256DC0007E4195
cheers chris
Message 8 of 10
(11,797 Views)
This should do what you want:
https://lavag.org/files/file/28-get-reference-to-all-controls/
edit: just saw the date on OP, anyways solution above for future searches
Message 9 of 10
(11,748 Views)
You can use the Traverse for GObjects.vi (Application Control / VI Scripting Palette). It works.
Here is the the Context Help:
Searches a target for objects of a particular type and returns an array of references to those objects. The target can be a front panel, a block diagram, or any object that can contain other objects, such as a For Loop, a cluster, or a user-defined control. This VI also recursively finds objects nested within other container objects.
Message 10 of 10
(11,736 Views)
