generating sinus-pwm for an (3ph) inverter control using myRIO
hello ,
i am working on an 3-phased inverter , and for the control i am aiming to use the sinus-PWM , i am using the myRIO 1950 with labview2013 , as a beginner i faced  problems in generating the sinus-pwm for the  phases , i found this thread ( https://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/10/thread-id/2590/page/2 ) it was helpful ,but i want to use the classic way ( comparison between a sinus signal and triangle signal ) .
if there is a way for   FPGA it will be very helpful
a appreciate your help , thank you .
Message 1 of 1
(273 Views)
