04-29-2013 04:44 AM
I have a small labview problem.
I want to generate a sine wave pulse with labview and send this to a pc oscilloscope by using my soundcard.
First VI I made creates a sine wave and sends it to the pc oscilloscope. Works perfectly.
But now i want to create a sine wave with only one period (second VI). Problem is then that the VI blocks if i want a high frequency (I need 10kHz)
So the VI works on low frequencies but gives this error with higher frequency:
"the sound driver or card does not support the desired operation."
Can somebody give a solution for my second VI (creating sine with one period on 10kHz).?
Thanks in advance!
Jelle
04-29-2013 05:21 AM
It could be down to the acceptable frequency range of your sound card. i know of sound cards that have frequency range upto 40kHz. Is there anyway you can confirm this?
04-29-2013 05:30 AM
But i don't have the problem with my first VI. Then i can go up to 30kHz with my frequency...
So the problem is not my soundcard i think?
04-30-2013 03:12 AM
Hello Benje,
The problem/difference you're seeing is indeed in the coding and also in the sound card.
In the "working" example you're using the Simulate Signal VI with the following settings:
- 44100 samples per second (sample rate)
- Number of samples 10000 (samples per generation cycle)
In the non working example you specify:
- sample rate = 1000*"Frequency Control value". This sampling info should be fixed to (for example) 441000 Hz.
- Number of samples 1000 (samples per generation cycle)
As a sidenote:
Is there any reason why you used different functions to generate similar signals in the 2 VI's?
