01-31-2019 02:13 AM
Hi guys, i was trying to create a constant voltage (1.25V) in labview using myrio 1900. I tried few times but still couldn't make it. Can Anyone help ?
Thanks in advance !
Solved! Go to Solution.
01-31-2019 02:26 AM
What did you try? Make sure you don't draw too much current.
01-31-2019 02:33 AM - edited 01-31-2019 02:37 AM
01-31-2019 03:05 AM
i try using analog input there but it is not working. I am new to labview. Please help .
01-31-2019 03:06 AM
Thanks for replying. What if I need to generate different voltage ? Where it could not be done using this method. Thanks in advance!
01-31-2019 03:34 AM
Hi boaxuan,
To output a voltage you should use an anolog output channel…
Did you notice that "Training" section in the header of this LabVIEW board?
You didn't ask for "different voltages". You asked for a constant voltage…
01-31-2019 07:10 AM
Hi guys, I am trying to generate analog output voltage in labview. Can anyone help me please.
01-31-2019 11:52 AM
Start with the examples.
Go to the "Help" menu in LabVIEW, select "Find Examples", then in the example finder, go to the "Hardware input and output" category, "DAQmx" subcategory, then "Analog output". There should be 7 in LabVIEW 2018; possibly different amounts for other versions.
