Is there any way to add a case to the matlab code which catches the "zero set of data" and allows you to pass something reasonable to LabVIEW? It could pass a value that would otherwise be impossible and you could check for that on the LabVIEW side to know that the the problem was the "zero set of data," and then take whatever action was appropriate.
I think that would be the easiest way to get around it - try to modify the matlab code slightly so that the error never occurs, and then just pass something that you can use to distinguish that case in LabVIEW.
Is that possible?
Best Regards,
JLS
