function to generate cosine and sine in FXP in Labview FPGA
Dear Enzo,
I followed your instructions, installing with "setup.exe" in the unzipped directory in the location you mention.
I see now the palette from the block diagram, but no vi of the library yet , as in the attached figure.
Should I run also the other exe in the directories , like"WindowsInstaller-KB893803-v2-x86.exe"?
Max
@enpe wrote:
you have to download  .zip file that you want to unzip and place in the following location:
--> C:\Program Files\National Instruments\LabVIEW 8.6\Targets\NI\FPGA\menus\FPGACategories
you can proceed with the installer. After you should be like this:
--> C:\Program Files\National Instruments\LabVIEW 8.6\Targets\NI\FPGA\menus\FPGACategories\Fixed-Point Math\
Containing the following .mnu files:
--> Dir.mnu
--> BasicElem.mnu
And so you should find the fixed-point library  in the palette.
Enzo
Message 11 of 14
(311 Views)
But are there the .mnu files in the created folder?
Enzo
Message 12 of 14
(309 Views)
Accepted by max_tomatis
Do you have any newer versions of LabVIEW installed on this machine?  By default, the installer will install to the latest version of LabVIEW.
Donovan
Message 13 of 14
(304 Views)
Thank you Donovan, I have uninstalled Labview 2010 and then installed the FXP library Labview 8.6,
now everything works fine.
Max
Message 14 of 14
(296 Views)
