04-11-2011 03:58 PM
i have a vi that whos front panel should display when the user clicks a front panel button(test instructions),
however this vi pops up when i run the top level vi. I can manually close the vi, but how do i stop this?
i tried modifying the Sub VI Set up properties, but that doesnt work.
Solved! Go to Solution.
04-11-2011 05:07 PM
So you went to Customize Window Appearance under VI properties and neither Show front panel when called or Show front panel when loaded was checked?
04-11-2011 05:14 PM
Also check the SubVI Node Setup (right-click on the subVI within the main VI). It is possible to set a single instance of a subVI to show the front panel when called this way.
04-12-2011 02:34 PM
Hi jknapp,
As egraham has pointed out, you can customize the window appearance of your sub VI from the VI Properties. If you go to File » VI Properties, then under Category select Window Appearance and then Customize..., you should be able to control how the sub VI appears. Hope this helps!
04-12-2011 02:52 PM
thanks that worked!
