frequency Analysis? How do I get frequency characteristics of a signal given in .wav format ?
I am new to Labview would really apprecite your time and help...
I have attached the signal I am trying to analyze.
Have nothing to offer in return but gratitude 🙂
Cheers !
Message Edited by Komal Khalid on 04-11-2010 10:59 PM
(4,850 Views)
You haven't actually attached the signal 🙂
Also what do you mean by characteristics? (harmonics etc?)
(4,837 Views)
Ya I couldn't attach it. It says the formaat not supported. :(....
I need to know what frequences are present. There is music and noise
http://www.2shared.com/file/12546495/2c481c77/STARTUP-HF-new.html
Heres a link to download
(4,829 Views)
If you have labview 8.x or 9.x you can do this. Go to help in the toolbar. Select "Find Examples" and then search for sound. Locate the "Sound File to Sound Output.vi" This example will help in your task. Remember that Labview is shipped with a lot of useful examples. That can help you in your learning process
Good luck
Ps you can also read wav files, and find examples  in Labview 7.x. But I do not know the name of the similar examples in 7.x
Edit: Please use zip files then you are not able to attach files. Do not link to sites outside. The site you linked to was very annoying. Could not download
Message Edited by Coq Rouge on 04-12-2010 02:38 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,789 Views)
