fpga i/o demo problems
I have been trying to follow along in this demo [broken link removed 1/15/26; article no longer available] and when I get to the first part, adding the FPGA I/O, I don't have any options to add in the window that is brought up.  I included a picture of the window that is brought up.  This must be something obviously simply that I am just not getting.
Message Edited by mnky9800n on 07-09-2009 01:59 PM
Message 1 of 8
(4,232 Views)
Can you post a screenshot of your Project Explorer window? Just wanted to know what target you are working with and how you have set it up, before we are able to help you.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(4,225 Views)
I have included the picture you requested.
Message 3 of 8
(4,201 Views)
Accepted by mnky9800n
You already have all of the possible I/O resources for your target added to the project so the dialog is telling you there is nothing else you can add.  If you expand the folders ModA and ModB, you should see these resources.  For many targets, adding the target to the project will cause the driver to query the target for all available I/O resources and automatically add them to the project for you.  The target used in the demo does not do this.  This is probably what caused you confusion.  If you delete the I/O contained in the folders and relaunch the Add New I/O dialog, you should see the I/O you just deleted as items available for selection.
Message 4 of 8
(4,189 Views)
ok thanks!  That worked!
Message 5 of 8
(4,186 Views)
I have same problem with adding FPGA I/O, but I didn't use any PINs in the project yet.
Message 6 of 8
(3,803 Views)
Also, How can I switch assigning the SDA and SCL pins to my sbRIO-9651?
Message 7 of 8
(3,798 Views)
Hi @hamidnaghi1234
Just wanted to mention, that this thread was solved and closed in 2009. If you want your question to have a higher likelihood of being read or referenced please make a new post regarding the issue.
Message 8 of 8
(3,792 Views)
