05-05-2014 04:46 PM - edited 05-05-2014 04:47 PM
I need to improve the pulse width noise of the DIO square pulses. With my current code (attached .png) I see ~25 ns jitter on the falling edge of the pulse (I trigger on the rising edge) with my oscilliscope. This jitter is present even with only a single square wave being produced (i.e. I delet the other square wave generators).
Any Ideas how to improve the pulse width fidelity?
Thanks in Advance!
Solved! Go to Solution.
05-06-2014 06:08 AM
25 ns is your clock period at 40 MHz, so the jitter is unavoidable at that clock rate. The square wave DDS algorithm produces a very accurate frequency over time, but can't control the rate at which it's called for updates.
If you set the loop clock to a higher derived clock frequency, you'll cut down the jitter by the same factor. Right-click on the 40 MHz Onboard Clock in the project under the FPGA target and choose New FPGA Derived Clock. You might have to experiment a bit to see how high you can set the clock rate without introducing timing violations in the compile; newer targets will allow higher clock rates in general. Set your single-cycle timed loop to use the derived clock, and also don't forget to update your Square Wave configuration with the new clock rate.
05-06-2014 09:02 AM
Your suggestion worked great. Thanks for the explicit instructions. I ran my SCTL at 80 MHz and found that the jitter was less than 5 ns.
