fpga Basic I/O Analog
I am having problems running the basic analog I/O with my 7833R card. I am getting an error -61024 with
Possible reason(s):
Labview FPGA: The device type that has been configured in ths function does not match the actual type of the device.
I have tried changing the driver so that the 7833R matched the 7831R device type in the program itself. No luck. I also tried to change the program to match the correct 7833R driver that the card is designed to run. No luck.
Any help??I look at my email hourly so I should respond quickly
(2,270 Views)
I'm not sure what you mean by changing the driver to match the device type, but I assume that you mean you're trying to use existing code with a different device that what you're wanting to use?
If that's the case, I'd suggest creating a new FPGA target in the same project (the device you want to use), then moving all of the necessary files over to the new target and compiling from there.
Also, what version of LabVIEW and NI-RIO driver are you using?
Austin S.
Academic Field Engineer
(2,243 Views)
