format decimal into string of 3 characters
I have been playing around with "Format Into String" function but haven't been able to exactly achieve this. I have a decimal number which might have any number of significant digits. I want to convert it to a string which will have maximum of 3 characters.
If the decimal number is 34.5343, it should give 34.5
If the decimal number is 34.0, it should give 34 (remove the unnecessary 0 after the decimal)
If the decimal number is 128.000, it should give 128 (remove the unnecessary 0 after the decimal)
(2,904 Views)
Accepted by topic author abdel2
Hi abdel2,
try "%#_3f" as format string...
(2,901 Views)
Perfect, thank you!
(2,893 Views)
Hi abdel2,
and the best is: I found all the information I needed in less than 2mins by reading the context help...
Why didn't you find it? (right-click ScanFromString, select "Help", then select "format string" to get a table of all supported format string options...)
(2,866 Views)
