for and case structure do not accept inputs
Hello everyone,
im trying to interate over the columns in my array that I read from a file: This is my program:pr.png
When I add an indicator to the size of my array it gives me the right number N that I want as my input to the for loop:for indicator.png
Now comes what I didnt expect: When I now try to attach that number to N, it gives me an error that source and sink are not compatible though of the same type:
Its not a big deal for my application so I just attached a constant because that array size does not change usually, so I had a workaround. The problem is that the weird error repeated to occur: I am trying to find out if the first element in my row is -1 and do something with that in a case structrure. So I used a comparison operator, that gives out a bool. If I add an indicator again, everything works as expected: as indicator.png
Now when i try to attach the bool to my case structure it ceases function:
I am working with labview for a few weeks now and came quite far but this confuses me a lot. Am I doing something wrong or is my Labview (v.2015) installation corrupted maybe?
Thanks for reading
derbengale
(1,082 Views)
Accepted by derbengale
Okay I see what I did there i attached an array instead of a single bool.. This can be deleted
(1,079 Views)
Hi derbengale,
When you want to autoindex columns instead of rows of a 2D array then you may transpose the array before the loop…
(1,046 Views)
@GerdW wrote:
Hi derbengale,
Adding just a bit to what GerdW wrote, you should not have the count terminal wired when you're using autoindexing. LabVIEW will take care of counting the length of the array for you.
(1,002 Views)
  • There is an optional input to the read function that gives you the transposed array right away If that is useful.
  • Taking a subset starting with zero and the length unwired is a NOOP and just returns the input unchanged. Why is it there?
  • Since you have an array for the comparison, but need to make a single decision, you need to decide if you want the case to be true if at least one element differs from -1 or only if all elements differ from -1. These are not the same. (Also be aware that comparisons (equal, not equal, etc.) on orange wires can be very dangerous.
I really recommend to start with some basic LabVIEW tutorials instead of jumping into the deep end and randomly wiring things together until no wires are broken. Even if there are no broken wires, the code can still be highly flawed. 😄
Also, it typically helps to attach your broken code (and example data file) and explain exactly what you are trying to do, not how you are trying to do it. Once we know what you want, we can probably come up with an alternative that fits on a postage stamp and is 90% simpler. 😄
(924 Views)
