fluctuating signal with usb 6212
I am using NI USB DAQ 6212 for measuring the pressure value from MPX2010GP. The output of the sensor is the differential one varies upto 30mv. For supply voltage to the sensor, I am using the 11.2 V battery.
I am getting the noise at the output. But when i am measuring it with multimeter its showing a voltage with no noise. I tried connecting only the differential input and also with connecting the AI- with AI gnd. But no improvement in the signal.
Looking forward for suggestions to stabilize the sensor output in labview.
(2,900 Views)
Accepted by topic author kashifsherwani
DMMs tend to have a lot of filtering, so they will not show noise.  Try using an oscilloscope to verify the noise.
(2,868 Views)
