08-09-2007 08:44 AM
thanks for any help.
08-09-2007 09:02 AM
08-09-2007 09:16 AM
If I understand just put that while loop with shift registers
and the stop linked to the end of the other while loop
jacques
08-09-2007 09:35 AM
When I create a sub VI out of my stacked led sequence, then put it in a test while loop, I only get 1 flashing LED.
Using a shift register, I don't see how I could programmatically start/stop the flashing.
seems like these simple thing get me stumped quite often!
08-09-2007 09:55 AM
send me you vi i'll try using shift register
jacques
08-09-2007 09:56 AM
08-09-2007 09:58 AM
08-09-2007 10:07 AM
08-09-2007 10:50 AM
My main program is based on a flat sequence structure, and when I enter a certain frame there is a delay while my data is plotted, I would like to display some flashing “LEDs” during the delay, once the data is plotted and I’m ready to leave this frame I want I want to stop the flashing and continue with the last sequences. The problem seems that when I use a while loop to create the flashing I just get stuck there until I manually click a stop button. I guess it boils down to how do I programmatically stop a while loop?
08-09-2007 11:22 AM
