firewire hard disk with cvs1450
i have connected a firewire harddisk to one of the iee 1394 inputs of
the cvs1450. i have checked in max under remote systems, cvs1450 that
the ni-1394 external drive support software is installed but no harddisk
appears under devices and interfaces neither can access harddisk via the
file transfer utility from max.
am i doing something wrong?
what i need to access to this harddisk programmatically from labview?
does the harddrive requires a specific format?
i have not found in documentation anything related to this.
Thanks in advance.
(2,218 Views)
i reply to myself.
i have followed
"http://zone.ni.com/devzone/conceptd.nsf/webmain/FF8AD4405E67BB1C86256F080
064F9D3" indications but is still not working. In the pc is working fine
with fat32 format. Any ideas?
peancor <peancor@hotmail.com> wrote in
news:Xns977876923F611peancor@216.196.109.144:
> harddisk appears under devices and interfaces neither can access
> harddisk via the file transfer utility from max.
> Thanks in advance.
(2,218 Views)
Hi peancor -
If you've gone through the External Drive Support article and still cannot see your drive, I recommend checking the FireWire bridge chipset in the drive.  This article gives a partial list of chipsets known to have SBP2 support:  Firewire (IEEE-1394) Hard-drive Enclosure Compatibility with Real-Time Controllers.
David Staab, CLA
Staff Systems Engineer
(2,210 Views)
