10-27-2008 09:27 AM
How can I know which row and column txt "Fail" exist in this table
thanks
10-27-2008 09:48 AM - edited 10-27-2008 09:55 AM
10-27-2008 09:52 AM
Hi Elyan,
If you know which column the Fail String is contained within, you can use the Index Array function to give you a 1-D array of Strings with the various status commands within. If you then use this 1-D array and use the "Search 1-D Array" to find any rows which are set to Fail. The attached image shows how to find the first Fail element.
