find letter assigned to USB pen drive
Hi to all,
I need to programatically find out the letter assigned to a USB pen drive,
after I plug it (in a Win OS)
I've searched, but I haven't find anything useful.
Could you help me, please?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,453 Views)
Hi Vix,
I'm not at all sure there is an easy solution.
If it were just a matter of spotting newly added drives - you might establish a list of existing drive letters on "first run", then check again as needed for newly appeared drive letters - but this would not spot a USB drive that was allready installed at first run, and would probably not be able to differentiate between other removable storage (CDs or floppies) either.
A clumbsy idea I know, but maybe better than nothing (or maybe not).
Mark.
(3,425 Views)
The problem is simplier, I think:
I need to know how I can obtain a list of existing drive letters. Also some informations about which kind of device is every letter would be useful, but it's not essential.
Thanks a lot in advance
Vix
Using LV from 7
(3,423 Views)
Hi Vix
There are vis by Mr. Borkowski to do that.
Will post as soon as possible. (Will try this afternoon, my local time)
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,414 Views)
See this thread for a solution by Altenbach. Then base your decision on size of drive.
(3,407 Views)
Here are the vis
Cheers
Alipio
(3,399 Views)
