file path too long
Highlighted
I am trying to load some code.  I have a type def cluster.  When I try to load it with my top level VI I can't because the "file path is too long"
Any sugestions?
Dan
Dan Shangraw, P.E.
Message 1 of 10
(1,810 Views)
Highlighted
That sound like an OS limitation. On Windows you're limited to 255 (256?) characters. Suggestions? Reorganize your directory structure or shorthen the names of your VIs.
Message 2 of 10
(1,807 Views)
Highlighted
Well that did it.
I never ran into that problem before.
Dan
Dan Shangraw, P.E.
Message 3 of 10
(1,804 Views)
Highlighted
That's probably because you never before had a full path that was longer that 255 characters. Smiley Wink
Message 4 of 10
(1,800 Views)
Highlighted
You are absolutly right!
I am trying to use more descriptive file folders and file names.  I guess I got a little to carried away.
Dan
Dan Shangraw, P.E.
Message 5 of 10
(1,796 Views)
Highlighted
I have been burned by this problem more than once.  The error messages are not always so nice.  Unfortunately, Vista did little to help the problem, so Windows users will just have to live with it.
This account is no longer active. Contact ShadesOfGray for current posts and information.
Message 6 of 10
(1,753 Views)
Highlighted
For followers of this thread:
Windows 10 now handles long file paths although it has to be enabled with via various possible registry or group policy edits. However, LabVIEW apparently has not opted in as of LV 2019 SP1.
I made a post on the LV idea exchange to make long file paths work in LV.
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Remove-File-Path-Length-Limitation/idi-p/4062640
Message 7 of 10
(358 Views)
Highlighted
Separately from the OS limitation, LabVIEW cannot handle more than 255 chars per element of a path.  That’s quite uncommon, but can happen when file or folder names are generated programmatically.
Message 8 of 10
(334 Views)
Highlighted
"LabVIEW cannot handle more than 255 chars per element of a path"
If you run into that issue i'd say you have some other problems! 😄
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 9 of 10
(308 Views)
Highlighted
I've always used the File Dialog Express VI to navigate to the file then open it using the Open/Create/Replace VI but have never ran into the 255 character limit. I wonder if that would work and bypass the character limit set by NI.
Message 10 of 10
(292 Views)
