Hello!
I wanted to unbundle a library of vi's into its separate files, so I created a new directory, went through the vi hierarchy, and exhaustively saved each of the vi's to my new directory. This turned out to be about 46 vi's. However, when I tried to work in my new directory in the top level program, the icons pointed to the library of the old directory. I would like them to point to the saved files in my new directory. So far, all I can think of doing is a "replace" with a dialog box to hand-select the desired vi inside my new directory. This will be very time-consuming... So I would like the top level program to link all the subVI calls (in the form of square icons) to "*.vi" files in my NEW dire
ctory. Is there a faster way to do this? They all have the same name, just the wrong path.
yours,
Raj Sodhi
