fan control through PWM using digital output of sbRIO
Hi all.
I am a new user of LabVIEW, so excuse if the question sounds basic.
I want to control two 4 wire fans (required for ventilation purposes) using PWM outputs. I am using sbRIO 9627 and would like to control digital RIO Mazzine ports (DI01, DI02...) to control the fans. I would like to know what could be the easiest logic in terms of LabVIEW VI that can control the fans rpm.
(1,803 Views)
Hi Satoo,
Sorry you've been waiting a while to hear back. I am assuming that you have managed to have this fixed by now, but if not, you can see some example code here:
https://forums.ni.com/t5/Example-Programs/Generate-a-PWM-Pulse-width-modulation-Output-Signal-On-cRI...
There's also this white paper that briefly describes PWM: http://www.ni.com/example/25979/en/
Nick
(1,710 Views)
