extract the channel name from the attribute data from a waveform
Highlighted
Good day
I am looking to extract the channel name from the attribute data from a waveform .
The data is generated using DaqMx create channel then passed to Analog 1D Wfm  read
I get the data but it seems to have a carriage return which placed it one line down and I cant find a wat to correct this so that I can sent the data to a array for the write measurement file.
(137 Views)
Highlighted
Accepted by topic author n3ow
Hi n3,
So you already get the requested string, but you want to add the TrimWhitespace function to remove CR/LF chars?
How are those channels created? Why is there a CR/LF in the channel name?
You can define the datatype you want to get from GetWaveformAttribute so you don't need to handle variants at all:
using LV2011SP1 + LV2017 (+LV2020 sometimes) on Win10+cRIO
(134 Views)
Highlighted
Thank you that will clean things up as well.
have a good day
jay
(119 Views)
