exporting data to excel
could it have something to do with the chart history length? I just checked on the front panel and it's 1024...
Message 11 of 15
(764 Views)
That is the normal default value.  It wouldn't cause a large block diagram memory footprint.
Message 12 of 15
(763 Views)
I found that when I increased the chart history length to 10240, I am able to export data to excel, however the data is largely the same and does not change within the resolution. Perhaps I'm sampling too much data?
Message 13 of 15
(760 Views)
That doesn't make sense.
Your loop is running at 1 kHz.  So you should have the chart history filled up in 1 second (with 1024 history).
If you can increase your data to 10240 and export it, there is no reason that you shoudn't be able to export 1024 points.
And whatever data you have in your chart should look the same once it gets to Excel.
I would suggest you step back.  Work with a new, basic VI with simulated data and a waveform chart and make sure that exports okay for you.
Message 14 of 15
(757 Views)
oh, I was thinking that there wasn't enough room for my data. Because I'm sampling at 1 kHz and I need at least around 6-10 seconds of the data...
Message 15 of 15
(754 Views)
