12-18-2006 10:53 AM
12-18-2006 11:02 AM
Tim,
Look at Tools -> Profile. This should give you all the information you are looking for about your VIs. It maybe only available in Professional Editions.
12-18-2006 11:05 AM
You can always use the "Tick Count (ms)" VI to get a ms value. So before a section of code runs get the tick count and than after it runs get the tick count. You can then subtract the 2 and there you have the time needed to run that section.
You will most likely need a sequence structure to ensure they are timed correctly. This is one of the few times I use a sequence structure. Of coarse you could also make a SubVI that returns the Tick Count, but also has error in and error out.
12-18-2006 11:20 AM
12-19-2006 06:17 PM
