executable not running properly even when running perfectly in development environment
Hello there
My application runs fine when running in development environment but as soon as I create build specification and run it, it takes time before reading signals and doesn't shut properly. I wonder if there is some settings I need to do in vi properties or in build specification?
Would appreciate comments
Kind Regards
Austin
(2,252 Views)
Hi Austin,
I'm Oli from NIUK.  I have a few questions that would help me to work out what the cause of the problem might be.
What type of build specification are you creating?
Did you receive any errors or warnings when building?
Are you running the built file on the development machine or another?
Would it be possible to send your project and files to me so that I can try to build it.  It could be an issue with your specific PC.
Kind Regards,
Oli
LabVIEW Student Ambassador
National Instruments UK
(2,209 Views)
