07-02-2009 04:50 AM
iám using the report generation toolkit with LV8.5.1 and Excel. How can i change the name of the sheet?
greetings
schwede
07-02-2009 04:55 AM
Hi Schwede,
see this link:
http://forums.ni.com/ni/board/message?board.id=170&message.id=337899&query.id=156373#M337899
Mike
07-02-2009 05:20 AM
But i don`t use low level vi`s. I use the report generation toolkit, where can i get the reference?
07-02-2009 05:53 AM - edited 07-02-2009 06:02 AM
You don't require low level Vi. You just have to work with property node and invoke node using activeX.
choose Select ActiveX Class > Browse.. option. Select the Type Library as Microsoft Excel 11.0... & the Object as _Workbook.
It ll automatically fetch you the Excel_Worksheet reference as the data.
07-02-2009 06:37 AM
07-02-2009 06:53 AM
Hi Schwede,
you can make it like this (see the attachment).
Mike
