07-04-2012 12:05 AM
Can anybody explain me how to do the Excel graph Y-axis label orientation.Can anybody provide the Code for this.
Thanks in advance,
Srinath.
07-04-2012 12:21 AM - edited 07-04-2012 12:22 AM
Hi srinath,
Open up NI_ReportGenerationToolkit.lvlib:Excel_Set_Scale.vi and expand the Axis class to show more properties.
I got an attachment and there you can see the Orientation property.I hope this helps.And if not give a further more explanation.
07-04-2012 12:40 AM
Hi Danil,
Tried the same way but "unknown system error 97" i got can you tell me how to overcome this situation.
07-04-2012 12:52 AM
Hi srinath,
Check you included the application in the excel vi's library, that you will find in the labview directory addons
07-04-2012 01:15 AM
Hi Daniel,
Can you explain me bit clearly,
Thanks for your quick reply.
07-04-2012 01:29 AM
Hi srinath,
Can you post the complete error description?
The error could have many sources, many of them possibly linked to YOUR specific machine:
- Depending on Excel/LabVIEW version (reproducable on machines only having the same Excel/LabVIEW version)
- Certain settings (reproducable only on machines using the same settings, so you got to provide those)
07-04-2012 02:19 AM - edited 07-04-2012 02:25 AM
Hi Daniel,
I am using Labview Version 10.0 and Microsoft Excel 2007 .
Error is :
Unknown System Error in File.vi
Error code is 97.
Possible Reason :A null or previously deleted refnum was passed in as an input
07-04-2012 02:59 AM
Hi srinath,
The error description is "A null or previously deleted refnum was passed in as an input."
Run your code in highlight mode. See where exactly you are getting error.Please check if you are closing any reference and using that Invoke node later in your code.
And If you can please attach your code.
07-04-2012 05:04 AM
Hi Daniel,
I Dont have permission to attach file.
I am getting the error at invoke node here reference is ActiveX class Graph.Axes
Taking the Excel_worksheet reference from the Get ActiveX References.vi. This is reference for the invoke node selecting OLEObjects method ,
Activating the object the object output i am passing to Varient to data typre vi, Here data type is ActiveX reference as Graph.Axes.
Output of that reference is giving to Invoke node item method ... Here i am getting the error.
07-04-2012 05:15 AM
Hi srinath,
Please see this link:-
http://forums.ni.com/t5/LabVIEW/Error-97-using-Active-X-property-node/td-p/334978
