10-20-2010 10:52 AM
hello,
every time i run my VI, values from the previous execution still exist and the new values get added after them.
i have to manually erase them by reinitializing to default values.
how to make it happen automatically?
please help.
thanks.
10-20-2010 10:55 AM
Are you using shift registers in a loop that are not initialized outside of it?
10-20-2010 11:02 AM
Hi tusharjain,
It would be helpful to see a screenshot of your problem.
If it is just front panel related, you can right-click on the control and go to 'Data Operations> Make current Value default.'
If using shift registers you can create a constant on the outside of the loop which you set to zero.
You can also initialize values using property nodes.
