Is it possible to monitor an indicator for a value change? I know this works with controls, but I'm not sure you can monitor and indicator in this way.
Yes, it's possible. However, in order to change the value so that an event will fire, you'll have to use the value(signalling) property of the indicator. It won't work if you simply wire a value to it.
