event structure latch controls not resetting
I'm having a bit of trouble with my controls associated with an event structure.
Controls stay active until the loop runs again, so I put in a reset case that gets called by an event programmatically.
What I find really weird, is that it works when highlight execution is on but fails to reset when it is off.
Anyone got any ideas?
Using LabVIEW 13.0f2.  Example attached.
Sean
(3,356 Views)
Hi Sean,
good advice: put buttons into the event cases where they are handled to allow the latching operation take place.
As I can't open your VI right now: did you follow that good advice?
(3,355 Views)
Hi GerdW,
That's the first thing I did, I expected it just to work but it didn't.
I just went back and changed a control to classic and tried again and it worked, (attached).
It looks like ti is an issue with the silver boolean buttons
(3,344 Views)
Try using the value change event instead of mouse down.
(3,331 Views)
When it comes to buttons, you should almost always
  1. Set to Latch When Released
  2. Use the Value Change event
  3. Put the terminal in the corresponding event case
Yes, there are exceptions.  But this will cover at least 90% of applications.
GCentral
(3,324 Views)
You also change the mechanical action. In the original code, the "rst" button was "switch until released" (like a car horn!). This generates two events, one when pressed and one when released.
What's the point of the signaling value property node?
(3,315 Views)
Probably to get the latching buttons to reset (must go through the loop at least once more for the terminals to get read).
GCentral
(3,307 Views)
