event structure cannot combine with other event and only run one time
Why It will always stuck when i Combine the "add new user" Event to the "Login" Event ??
It work for me when i separate two but "add new user"button can run but only one time for the above structure,program will stuck on the second time i press the "add new user"button
Message 1 of 9
(3,855 Views)
Anyone?
Message 2 of 9
(3,841 Views)
I don't see anything done correctly. You should have one event structure with multiple events. You're event structure needs to be inside a while loop. Don't use the run continuous nutrition. Don't use local variables. You have a classic race condition.
Message 3 of 9
(3,811 Views)
When i combine the "add new user"event to the "login"event ,the whole front panal stuck when i pressed "add new user"button
why would it happen?
Message 4 of 9
(3,801 Views)
Are you sure the login event has finished? Attach a VI with the correct design pattern.
Message 5 of 9
(3,790 Views)
can u please hint me how should i suppose to do it ? im not sure where is wrong
Message 6 of 9
(3,788 Views)
Accepted by gary333
It was already told you, you should use only one Event structure and not 2. Also, avoid using local variables (better to store data in a shift register, and not in an indicator) how you do, it can cause nasty race conditions.
Actually here you just do not need other data storage since you have a file. Do not store data file in the root of the C drive, you may not have write permission. Use Default Data folder or the application folder.
I have attached a simple example. I guess this is a homework? Please make my help count: try to understand why your VI does not work, and try to find a solution by yourself. Modify my example, and play with it. This is how you can learn LabVIEW. If something is not clear, post here, and we can explain/help.
edit: at the "login" Event case, I do not check against whether the file exists or not. Fix this part, also gives some practice.
Message 7 of 9
(3,771 Views)
Thank you~
Im sorry bcos i dont understand just now...
Thanks for your sample
this is much appreciated.
Message 8 of 9
(3,750 Views)
If you don't understand the answer that was given, you're in WAY over your head and the example won't really help you too much.  Instead of trying to push forward, take a few steps back.  Learn about LabVIEW.  Take free tutorials.  THEN, try to do what you'd like to program.
Message 9 of 9
(3,725 Views)
