event refnum
How do I make a'Cluster of Event Refnums for the input cluster of a bundle by name. I am trying to understand the function of an existing code, in the code he has used a cluster of event refnums as the imput for the bundle by name. Unfortunately, I can not even duplicate his code, because I can not figure out how he made the Event Refnum icons in the first place. I am new to LabVIEW and would appreciate any information you can provide. Thank you for your help,
(3,024 Views)
The Dialog and User Interface >> Events palette should have everything you need.
A User Event Refnum is generated and is specific to the datatype that it is registered with.
Cheers
(3,021 Views)
Accepted by Crumb
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(3,013 Views)
Thank you, that is exactly was I was looking for, but did not no how to ask!
Luke
(2,974 Views)
