I've been using the carrier board to develop/debug code for the sbRIO-9651 SOM but I´ve apparently managed to kill the Ethernet Port 0.
The problem occurred while downloading my RT code(hence also the FPGA bitfile). There could´ve been a brown-out while doing it.
Hardware:
- sbRIO-9651
- SN 01E7A6D8
- Firmware version 7.0.0f0
- OS NI Linux Real-Time ARMv7-A 4.14.87-rt49-cg-7.1.0f0-xilinx-zynq-41
Current state:
- eth0 doesn't work, no lights, no connection
- eth1 works fine
- usb as well
Steps taken so far:
- Tried both safe mode states
- Tried re-flashing the firmware with the same version 7.0.0f0
- Deleted and reinstalled all the software packages installed on the Labview RT
I suspect a piece of software that handles the Ethernet port 0 got corrupted in the process.
Any suggestions?
