04-25-2017 09:14 AM
Hi guys,
I have got this error when i run the labview. Can anyone help me out here?
04-25-2017 09:40 AM
Seriously? Where did you get Velodyne HDL-64E S2.lvlib? How are you using it? How are you connected? Did you read the manual?
04-25-2017 09:47 AM
I have got this sample code of the HDL-64 which i'm trying to customize to make it work with the velodyne 16 channels sensor which i have.
04-25-2017 09:52 AM
You missed the link. And, what ever gave you reason to think that the same code would work for the other device? Serious question since I can't see the source or the product documentation.
04-25-2017 10:32 AM
The same code obviously won't work as the sensors have different requirements. however i was wondering knowing the sensor requirement for the VLP-16 i thought i could see how can that source code be adaptable to my need and was wondering if some one has an idea on how to go about it or has done similar as now still novice in labview as well
04-25-2017 10:41 AM
Not without a link to the manual and the existing code
04-25-2017 02:06 PM
sample that I'm using is here:
04-25-2017 02:14 PM
Hi all,
I'm new in Labview and started working on velodyne lidar sensor. Im trying to do a requirement analysis of this sensor. My question is : Is there something done on VLP -16 with labview. I have seen the NI visa example of velodyne HDL-64 and was wondering how can it be customize to the 16 channels however an error keep rising that i need to the sensor it but even when doing so it show a tcp error which i have not figured out.
the sample i'm using and trying to adapt to VLP16 is this : http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=761147DDA1E02BC0E04400144FB7D2...
and I have going the error showed.
Has anyone done anything on VLP 16.
many thanks
04-25-2017 02:25 PM
02-25-2019 02:58 PM
Hello
i'm new to labview and i just got it installed. I'm trying to connect to VLP-16 but i dont see any sample code or design that i can use for this!
Anyone can help with this? Can someone provide a sample code for Velodyne 16-channel LiDAR to be implemented and visualize in labview?
ismail
