error occurred while building the following file
hi,
i get an error while compilating my programm. i did not change the vis listed below, they are standard express vi's...
An error occurred while building the following file:
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\express\express analysis\CurveFittingBlock.llb\subCurveFitting.vi
Error 1003 occurred at ABAPI Dist Chg and Save VIs.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Rule_Editor.vi -> BUIP_Create_Build_Rule.vi -> EBUIP_Global_OnCommand.vi -> EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW:  The VI is not executable.
(2,572 Views)
I would recommend to update to at least LabVIEW 8.0.1 (free update) and masscompile the vi.lib folder.
You can download the update here:
http://digital.ni.com/softlib.nsf/websearch/4C1209D42320BCFD8625711C005FB25B?opendocument&node=132070_US
(2,550 Views)
