error: connected two terminals of different types
The array size is much bigger than 256 samples. That's my problem
Message 11 of 16
(802 Views)
No, it is not - debugging clearly shows that. The problem is that you only evaluate the last waveform of probably many waveforms you've aquired!!!
Regards, Jens
Kudos are welcome...
Message 12 of 16
(797 Views)
Accepted by topic author GM1710
Hi GM,
you use a chart to look at the acquired waveform.
The chart has its own buffer to keep a history - but not the waveform wire you use to transport data out of the loop!
Options:
- do the calculation inside the loop
- create your own buffer for sample data
- use autoindexing at the loop border
Select which one fits your needs best!
Message 13 of 16
(787 Views)
Hi Gerd:
Thank you, the code is working now.
But I have still another question. If I have a multiwave how can I get the waveform of each of them? Is there a function like "get a wave form" for a multiwave?
Message 14 of 16
(773 Views)
Sorry: "get waveform components" is the name of the function, which I refer to
Message 15 of 16
(772 Views)
We already had that, this is an array of waveforms. To access the elements of an array, use Index Array. In order to execute some part of a vi for all elements of an array, use a for loop.
Regards, Jens
Message 16 of 16
(759 Views)
