error DAQ 6008, 6003 usb no tranfer data
hello I want to comunicate the daq 6008  in labview 2016, 64 bits win7, but when i do differents test the daq didn´t  take the data, I need desconect the usb in my computer and run de VI in labview,  the problem is that this problem is constant every day, the values are analog, by the daq 6008 and 6003 is digital.
thank for your answer.
(2,897 Views)
Can you talk reliably with the DAQ units using MAX?
Can you show your code?
Are you getting any errors? What are they?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,852 Views)
I have slightly different hardware, but I have no trouble acquiring multiple analog channels at 1KHz from a USB-6002 or USB-6009 using LabVIEW 2016 (32-bit) on a Windows 10 (x64) Laptop or a Windows 7 (x64) Desktop.  MAX works, the usual 4 DAQmx Functions (Start Task, Read Multiple Channels/Multiple Samples, Stop Task, Clear Task) get the data.  I usually define the Task in the LabVIEW Project or in MAX ...
(2,846 Views)
