error -89137 with using m and s series boards
for various input/output operations we are using a PXI 6229 m-series and a PXI 6122 S-series board. Both boards are synchronized similar to figure 9 of the tutorial under the following link: http://zone.ni.com/devzone/conceptd.nsf/webmain/6DC991028566309886256F990080A720
This works fine, however now additionally we have to implement an input counter similar to the Count Digital Events Buffered-Finite-Ext Clk.vi example. This results in error -89137 stating that it is no longer possible to route Master.Timebase.Src of PXI 6122 to Ref.Clk.Src of PXI 6229 (necessary for synchronization) as the resource of this route is already in use by the counter configuration.
Does anybody have an idea how to circumvent this problem?
Thanks a lot for your help!
(2,917 Views)
Hello Werner
Is it possible to attach your VI?
This would it make easier to find the error.
regards
Manuel
(2,895 Views)
